High velocity heat pumps info
In_New_England
Member Posts: 166
Being forced to abaondon my oil to gas conversion may not have been the worst thing (For those of you who have read me ranting about this, yes, I am in the acceptance stage of grief).
The plan hatching in my head is as follows: Before my existing heating system completely goes, I will
1. Upgrade my electrical (currently 100A fuses)
2. Install high velocity air
3. Test it out in winter to check if I can get by without baseboards
4. Discard the oil heating when it breaks after having worked out the weaknesses of the heat pump system
I am thinking about high-velocity because
1. Our home has no room for ducts
2. We'd need a bunch of heads for mini-splits and we'd have cold spots (bathroom etc.)
3. I rather fancy having just one unit in the attic, draining condensate down via gravity, with one filter I can replace myself rather than a condensate pump that can break and many filters to manage
What do you experts think of my plan and what should I know about high-velocity systems?
I'm near Boston, 1400 sq ft 2 story home + basement we never heat/cool. Basement is 1/2 unfinished and pretty exposed in case we need to run high-vel ducts, attic is accessible but with some gymnastics.
Thanks!
Thanks!
Ok, two independent heat pumps? The attic one would travel in uninsulated space, unless I added more blown in, over the ducts, which would work.Hot_water_fan said:What about two ducted systems? One located in attic, one located in basement. Might be an easier approach.
I worry about the basement - it's not that high - we'd bang our heads against the ducts, but an idea, thank you.0 -
Also, would we need a 200A service or could we get by with the 100A one for heat pumps? Would likely add a heat pump water heater too, in the basement, unless folks have a better idea for hot water. Electric, on demand? But that would likely need an insane electric capacity.0
Also, would we need a 200A service or could we get by with the 100A one for heat pumps? Would likely add a heat pump water heater too, in the basement, unless folks have a better idea for hot water. Electric, on demand? But that would likely need an insane electric capacity.Depends. Two would be around 40 amps total if they’re cold climate 2 ton models. Maybe a bit less. If you don’t need resistance backup, it’s easier. Or a furnace backup can save you some amps. It all depends. Electric on demand water heaters are the worst of all worlds! Inefficient and need huge amperage, so either a heat pump tank or resistance tank would be better if you have space.1
