Length (sections) limit on a cast iron radiator?
Lambini
Member Posts: 11
We disconnected, sand-blasted, painted two National Art 16" window radiators that were 28 sections each and connected together by threaded pipe. We are reducing the number of sections to 42 (from 56 total). The sections use push nipples and rods with feet only on the end sections. Is there a limit to how many sections can be put together, or is there enough support with just the push nipples and rods? I couldn't find any info in old catalogs or manuals. Thanks.
I don't know what the limit is, but I do know I've seen longer ones with another set of feet in the middle.1
According to an Arco hand out sheet dated 1959, their radiators were supplied in widths of 3,4,5,and 6 tubes and up to 56 sections long with no mention of center feet. So I would have to assume that 56 sections was their maximum recommended length for their radiators. They came with 1" malleable nipples on the 3,4,and 5 tube and 1.25" on the 6 tube radiators.1
Thank you everyone for your info and insights. It's so great to have people that are willing to help on something like this! BTW, random12345, 6-tube, section thickness 7/8" (1-3/4" on btm), section width 8", push nipples 1-3/8" OD.0
I agree with @retiredguy . The max appeared to be 56. Section thickness is measured from the top/bottom from where they connect to one another, not the tube itself. I think it will be ok, but this chart shows the max stock assembly standard for 6 tube 19" tall was only 38 sections:
https://babel.hathitrust.org/cgi/pt?id=mdp.39015035429805&view=2up&seq=1707&size=200&q1=r174-40
I would play it safe and put a block of wood with/without some of those cheap wood wedges underneath. Never flip a radiator onto its side, keep it upright always.0 -
This should be in the "funny story section" but it may be appropriate here. In the early 1970's, when I was quite new to the trade, we were trying to take a very long radiator (the longest I have ever seen) from a second floor room to the first floor to be put on a truck for some reason. They built a ramp down a pair of steps to slide this rad on. As soon as it started down the steps it got away from everyone and slid down that ramp like a runaway freight train. It crashed through the 1st floor and into the basement. What a mess and an insurance claim. At this point they decided to take it apart into manageable pieces. True story.1
You guys are great! I did carefully take the radiator apart into manageable pieces (6 or 7 sections). Unfortunately, my labeling didn't survive the sandblasting, so now I either need to figure out which sections can rejoin without removing its nipple(s) or is there a good way to drive the nipples out from the opposite side?
Retiredguy, had a similar experience with an ARCO 32" 3column/5section radiator that slipped off my appliance dolly and literally "walked" down our steps like it came to life, sort of like the teapot or candelabra in Disney's Beauty and the Beast, dancing its way down the stairs. No one hurt, didn't hurt the radiator, steps took a beating toward the bottom though.0 -
Was working at my desk at the shop when two of our guys came back from a job with a good-sized radiator. I went out to help them get it off the truck so "they wouldn't get hurt". The one that ended up with a broken toe was me.
At the hospital the nurse and doctor laughed at me. I guess they were thinking car radiator1 -
Need to ask again, is there a good method to remove a push nipple from a section and be able to use it again?0
Not really -- but all the nipples should be the same, so unless they are damaged it shouldn't matter anyway.Lambini said:Need to ask again, is there a good method to remove a push nipple from a section and be able to use it again?
My issue is that we're reconfiguring how many sections to use because we've remodeled and reduced the room square footage; radiator will now have fewer sections. The radiator pieces (6 & 7 section 'chunks') that were once together, now won't necessarily be the same ones rejoined as originally joined. Some have the push nipples, some don't, some have 1, 2, 3, 4 or none attached. So in some cases, I need to either remove or rob push nipples from a given piece to accommodate how they will rejoin to make up the total radiator. Hope that makes sense. Thanks!0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
