Summer draining
stevenknaub
Member Posts: 36
If I am not using my one pipe steam boiler six months or more each year, would it be beneficial to open all drains, boiler, and return lines, remove all radiator vents, and leave everything open to the atmosphere until heat is needed in the fall?
I read something similar on this site when a certain author named Clark I think was mentioned.
Could the drained water be covered and reused?
All of the vents are open when the system is off. There's no reason to touch them.stevenknaub said:If I am not using my one pipe steam boiler six months or more each year, would it be beneficial to open all drains, boiler, and return lines, remove all radiator vents, and leave everything open to the atmosphere until heat is needed in the fall?
I wouldn't drain the boiler.
I try to overfill mine about an inch on the gauge glass at the end of the heating season so I'm sure all of the fresh water is boiled before shutting down.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Not a pro, just homeowner. Agree with the above.
Boil first, then fill.Overfill, then boil. Read your boiler's manual if available. It will likely tell you to do the same thing. From what I gather corrosion occurs primarily at the waterline. I have a steam boiler, here's what it says in my manual, page 48:
https://s3-us-west-2.amazonaws.com/catsy.782/MegaSteam+IO+Manual.pdf
- 50 Industry Classes
