Radiant heat system issue
esstee
esstee Member Posts: 1
The thermostat works to turn on the system when needed. It runs fine, the heater
works fine. The heater isn't being told to heat when its needed to heat. When I force the hot water heater to heat the system works perfectly to heat up and run. The issue is I can't be there to force the hot water heater on all the time. Any ideas? Thanks so much in advance
    hot_rod Member Posts: 27,455
    Snap a pic of your system and attach it
  • GroundUp
    GroundUp Member Posts: 2,513
    First you said it works, and then you said it doesn't work. Which is it?
