Propane stove burners surging
scooter2219
Member Posts: 1
I have a travel trailer and my stove burners are surging. I replaced me regulator just under 2 years ago. I'm thinking that it's being caused by the regulator but don't want to replace it because of how new it is, though I am not against the expense if it truly did go bad already. Thanks for the help!
Hi, Is there any chance of having water in the lines? If so, it could be the cause of the surging. Compressed air would be used to blow it out, but propane is not to be messed with unless you have the skills to work with it safely. If that doesn't work, then the new regulator might be in order.
Yours, Larry0 -
Presumably it did work properly for a while before it started surging ?
Afaik, trailer regulators are always 2-stage (the model number will be stamped on it somewhere, can look it up to verify). There should be a vent screen on the regulator, might be under a plastic cover, check it's clean, it should always be facing downward.
Also, if you leave a hose disconnected from tank for a while, bugs can crawl in the hose fitting hole and cause issues apparently.
Currently in building maintenance.0 -
- 117 Geothermal
