Tekmar type 117 - 1 1/4" OR type 116 - 1" mixing valve needed
copjsd
copjsd Member Posts: 2
edited October 2022 in THE MAIN WALL
I'm in search of a Tekmar type 117 - 1 1/4" or a type 116 - 1" 4-way mixing valve. They have been discontinued and all of my searches have been fruitless. If anyone would share with me the whereabouts of a new or used (in functional condition) it would be greatly appreciated! Please contact Joe at 412-480-6250 or copjsd@comcast.net . Thank you!
    hot_rod Member Posts: 27,426
    Supply House.com shows them available
    Danfoss, Belimo are other options. I think the mount holes are the same
  • copjsd
    Hello, Bob, and thank you for your reply! I spoke with Supply House and they haven't had the type 117 (1 1/4" 4-way mixing valve) in years. All the newer mixing valves have a different CV rating as well as won't fit the installation area without a substantial rework of the copper. I would even size down to a Tekmar type 116 (1" 4-way mixing valve). Please, I'm open to any suggestions!
    I’ll bet some of the tekmar reps might have some on the shelves yet.
    Where are you located?
    Rathe and Associates in NY has a room full of older tekmar parts
    Shamrock in Colorado
    Lundquist in Salt Lake
    check the tekmar site for other reps.
    E Bay?
    What is wrong with the old one? Not much inside them, unless the vanes are broken?
