AO Smith Burkay Replacement
All: Not sure I've seen this post yet.
I'm looking to replace my old AO Smith Burkay 240K-BTU HW Boiler. It is likely from the 60's based upon some feedback. Contractor is suggesting Trinity TFT. I understand at 180F these are not as "efficient" as if we ran at 140ish F.
Does any one have experience good bad or indifferent with these boilers?
    mattmia2 Member Posts: 16,769
    Do you need to run at 180? What emitters is is connected to?
  • Sonor3000
    Sonor3000 Member Posts: 16
    Connected to old cast iron radiators. The current boiler runs at 180F, so I thought I would keep it the same to "match" the heat.
