Spirovents and hydraulic seperator
Cometfab
Member Posts: 1
Is there an advantage to using both spirovent and hydraulic seperator on same system? If so, which one would be piped in first? If not, do you just pipe in the feed with extrol tank prior to the seperator? This will be on a HTP versaflame boiler.
Assuming primary/secondary piping, you'll need some method of hydraulic separation but you'll also need air removal. This can be accomplished with an air eliminator (like a Spirovent) and closely spaced tees, or with a good hydraulic separator which serves both functions. If you're using a hydrosep regardless, adding a Spirovent is nothing more than a leak point IMO.0
- 117 Geothermal
