Rusty NEW MoM main vents
Jim_X
Jim_X Member Posts: 23
Just had three MoM #1 vents ordered for me. Not looking for a discussion on Gorton vs MoM. I can't fit a #2 vent and money is tight. Regardless, the vents all had rust in them on the bimetal strips.  The vents are new, the boxes were dusty but new and no signs of water damage. The vents are new and have no signs of being installed. Date code has them made in 2020.
I spoke with MoM and they are sending me replacements and want the old new ones back to cut them open. one I pulled off the shelf a couple years back and have had in use has no rust in it.
Also spoke with MoM about no supplies having the vents on the shelf. All you can get here are Ventrite #11 and #35s. They also told me that in 2019 they stopped production in China and brought it back to the USA.
  • Jim_X
    Received my replacements today. All 2020 vents....and all rusty as well. Not sure what the deal is. Has anyone else seen this before?
    109A_5 Member Posts: 3,394
    You would think they would check them before they shipped them. Maybe that is just how they are made (materials wise). Do you have an old failed one to dissect ?
  • ChrisJ
    ChrisJ Member Posts: 17,060
    Rusty old bi metal is how they're made?
    @ChrisJ, I'm waiting for your explanation. They look unused on the outside, maybe they are 100 years old NOS item, 1920 not 2020. Maybe Scotty beamed the rust in there just to mess with @Jim_X. Maybe they are counterfeit but I believe @Jim_X got the latest ones directly from MoM.
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    The bimetallic strip has to be made of hardened steel so it will consistently return to the same shape over multiple thermal cycles. This layer can’t be plated because this would add an additional layer of unlike metal and change the thermomechanical properties of the spring, but it is somewhat protected from rust by bluing; however, some rusting can still occur, but this will be superficial and will not affect the function of the vent.
    I assume that the rust you see on new products is there because they test the finished vents before they ship them. If they want to prevent this, they could add a post-test drying step to their process, but if customers aren’t complaining, it’s not worth the expense, so I assume they don’t see it as a problem.
    If the vent you have isn’t closing to steam, try turning the vent upside down and blowing into it and see if it closes. If it doesn’t, the defect is in the float or the valve seat. If it does, then there is something wrong with the bimetallic spring or how it’s assembled, but it probably has nothing to do with the surface rust.
    Jim_XChrisJ
  • Jim_X
    edited September 2022
    My old vent is fine, just had room to make an antler add more vents. MoM or Gorton #1 is the tallest I can really fit.
  • Jim_X
    Does anyone have a Gorton #1 around and would care to take pics?!
    Hello @Jim_X,
    Maybe this will help.
    Deep Dive Into Gorton #2 Main Steam Vent Construction & Failure Modes
    https://youtu.be/s-g0YSu8Bbo
    Gorton #2 Main Steam Vent With Nothing To Hide
    https://youtu.be/LeYDZvD7NmI
    Gorton / Maid-o-Mist Single Pipe Steam Radiator Air Vents
    https://youtu.be/0ugIrg9bquk
    Jim_Xpfk
  • pfk
    pfk Member Posts: 1
    See attached image of Maid o Mist vent after less than 2 yrs.
    An that is why I keep my old vents that are probably more than 50 years old and work fine.
