Toilet Help
The Kohler is canister and the American Standard is gravity.
Any thoughts?
Thanks!
Been in the trade for 30 years and I like the pressure assisted toilets. Only problem is the tanks fail from time to time. but they sure do get everything out of the bowl. They don't clean the bowl real well thou. Some gravity flush toilets have a hard time getting the real fluffy toilet paper pass the trap. Pros and cons on both sides. I tend to try and find a bowl with a high water level. Keeps the bowl cleaner. whatever you chose, go with a comfort height toilet. little bit taller bowl is great. I don't need it i just like it.0
Oops, I thought "canister" implied pressure-assisted.
Just to clarify: should I go with a gravity-fed with a FLAPPER or CANISTER?0 -
I prefer flappers.I used Toto Drake for many years but now use the Kohler Cimaron. Nice quality and can source from local big box.0
PC7060 said:
I prefer flappers.
Are all Toto Drakes the same as far as parts and performance?
If you buy one from Homer, is it essentially the same as any other Drake?
Performance seems to be consistently high for Toto products as represented by the higher $.ChrisJ said:Are all Toto Drakes the same as far as parts and performance? If you buy one from Homer, is it essentially the same as any other Drake?
Having said that, I’ve seen no difference in performance between the Drake and the Kohler Cimaron units. At least not enough to pay the extra $100 or so
I can’t say I’ve ever seen a Toto toilet in my local Homer or Lowes. Ferguson’s is the source around here0 -
Performance seems to be consistently high for Toto products as represented by the higher $.PC7060 said:Having said that, I’ve seen no difference in performance between the Drake and the Kohler Cimaron units. At least not enough to pay the extra $100 or so
Homer has them on their website.
There's also 1.6 and 1.25 gal flush Drakes.
There are different 'Drake' toilets ...... by all accounts the basic Kohler toilets now match the Toto in performance. That said I always put the slightly more expensive Drake in my rentals .... there is a Drake II now with the high performance porcelain (like the euro toilets) and lower gpf for use in ca/tx. Gets confusing because they do now sell a lower gpf Drake. The Drake II is better looking w/ advanced jet flush.
The pressure assist -- the real deal with the pressure tank. Great for problem spot --- my last house had a lower level toilet that must have had a low slope in the drain -- the pressure tank solved all the issues. Would scare the dog ... but -- ended the need for a plunger.
Kohler canister is just a new flush design ....
The euro porcelain does make a difference .... have been installing Duravit wall toilets w/ it and it does basically self clean.
Higher priced toilets are looks -- one piece are nice looking and easier to clean0 -
Which is easier to source parts for, and will likely have parts available 20 years from now?TAG said:There are different 'Drake' toilets ...... by all accounts the basic Kohler toilets now match the Toto in performance. That said I always put the slightly more expensive Drake in my rentals .... there is a Drake II now with the high performance porcelain (like the euro toilets) and lower gpf for use in ca/tx. Gets confusing because they do now sell a lower gpf Drake. The Drake II is better looking w/ advanced jet flush.
Higher priced toilets are looks -- one piece are nice looking and easier to cleanSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I’m not in the trades but I am a handy diy homeowner and have replaced both of my toilets in my house. I put in Eljer brand from big box stores. Very basic tank with flapper and flush just fine. I think Eljer is part of the American Standard (plumbing - not HVAC) company.Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
I prefer the American Standard Champion 4 or Vormax. Each has a fully glazed trap way for smoother exit flow, and the outlet diameter at the horn is much larger than other similar priced toilets ........0
The outlet diameter is much larger?MikeL_2 said:I prefer the American Standard Champion 4 or Vormax. Each has a fully glazed trap way for smoother exit flow, and the outlet diameter at the horn is much larger than other similar priced toilets ........
How much larger can it be?
Parts are not a problem ... even with Kohler always going a different way you can always get the parts -- especially with Amazon.
The reason to go with the Toto or American Standard when buying a basic toilet -- they work.
I recently bought a 10 year old condo on the coast of SC and it has three Kohler toilets w/ the canister. I replaced the seats and the gasket on all of them just in case .... very easy no issue with parts. Non from the low end line .... one piece -- for what they cost I would have bought something else
Working is very important when it comes to toiletSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The Eljer brand I used is also full glaze to outlet.Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0
Reading Consumer Reports -- they all seem to work now but the Drake gets the best reviews in the basic toilet category when they load the balls into it.ChrisJ said:TAG said:Parts are not a problem ... even with Kohler always going a different way you can always get the parts -- especially with Amazon.
Not all toilets have the two settings. In wall toilets have the best flush because they can get the water up high and dump the whole tank .....0 -
I wish I could convince the wife to let me get a pressure assist toilet for the main bathroom.TAG said:
They just seem to always work better. Except the ones that explode, unless you want better demolition of the bathroom....
The diameter is up to a 1/2" bigger......ChrisJ said:I prefer the American Standard Champion 4 or Vormax. Each has a fully glazed trap way for smoother exit flow, and the outlet diameter at the horn is much larger than other similar priced toilets ........
The outlet diameter is much larger? How much larger can it be?0 -
Yes -- they work .... but not quiet. Both that we had were loud .... loud that we would tell new people to the house. I'm an old house guy -- so odd bathroom spaces that require strange pipe layouts that don't always work as well.ChrisJ said:
They just seem to always work better. Except the ones that explode, unless you want better demolition of the bathroom....0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
