Corrosion on tankless heater
I forgot to add in my original post that the elbows attached directly to the heater are stainless steel0
Thanks for the response. Even when the system has been off for several hours, there is no signs of water. A leak is what I first suspected.0
The condition of the water might or might not be relevant -- but the water has to get to that location first. That means a leak. It is more likely that it will drip when the system is running hard than when it's been off -- indeed, that may be the only time it leaks. I'd agree with @mattmia2 as to where the leak might be -- and my first guess would be the threads.Br. Jamie, osb
If it is bothering you, then you should disassemble the subject fitting clean it with a wire brush, put a coat of fresh paint on the coil face plate and put a brass nipple with a good thread sealant into that coil tapping. Some will tell you to use teflon tape and pipe joint compound. This is what I have done in the past. the problem is getting it tight enough and also pointing it in the proper direction. Never turn that fitting backwards to get the elbow to line up
Since you have a new boiler (18 months) you may want to take a 1/4 turn on all the coil plate bolts. You won't believe how loose they are, since that gasket has been heated and cooled several hundred times. This will keep that gasket from leaking and looking like that fitting does.Edward Young Retired
2 -
Thanks to all that responded. While the tankless heater is 18 months old the boiler is 20 years old. the nipples that go into the heater are stainless and were wrapped with one turn of teflon tape, then pipe dope over top of it. The 90's are stainless steel, and then a copper male is screwed into them. Originally brass were ordered by the supply house that supplied the heater said they were no longer carrying brass and were only carrying stainless. Thanks again to all0
New Boiler or just new coil and gasket. The same thing applies. Give those bolts a 1/4 turn. That new gasket is now 18 months old and will shrink the same way. It don't know the age of the boiler. it just knows its own age. (see that... I said the gasket, an inanimate object , knows its age) That is an example of personification in case @Alan (California Radiant) Forbes is watching.zepfan said:Thanks to all that responded. While the tankless heater is 18 months old the boiler is 20 years old. the nipples that go into the heater are stainless and were wrapped with one turn of teflon tape, then pipe dope over top of it. The 90's are stainless steel, and then a copper male is screwed into them. Originally brass were ordered by the supply house that supplied the heater said they were no longer carrying brass and were only carrying stainless. Thanks again to all
especially if the threads on the stainless were a little out of spec.MikeAmann said:One wrap of teflon tape is not enough. 3 wraps minimum - more as the fittings get larger.
I'd put some anti-seize or teflon dope on those studs although the brass nuts should keep it from seizing in itself.0 -
I went by the job today and removed the aqua stat to get a better look . It appears that the head of the tankless heater is where the leaks are developing. The surface is wet and appears flaky. A picture is attached
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
