Mini Splits refrigerant line insulation help.
JackW
Member Posts: 236
I have a four-unit Mitsubishi Mini Split cooling/heating system. All the lines run outside the house because we are on a slab. As you can see in the pictures, the lines are covered by formed aluminum sheeting. Since it wasn't sealed very well, mice and chipmunks have had a field day inside the sheeting, using the insulation for their homemaking. I'm in the process of taking all the covers off and repairing the exposed copper pipes. Most of it has been small areas that I have wrapped double-backed aluminum foil insulation around, then sealing it with PVC and aluminum tape. As you can see, they wreaked havoc with the up lines out of the condenser unit. Given the amount I have to replace, is the aluminum foil insulation ok to use, or is there a better alternative? The lines are 1/4" and 3/8," I can't find any type of foam insulation that small of a diameter. Any suggestions will be greatly appreciated.
Jack
Jack
I'm pretty sure this is the size for 3/8" tube. You might need to find someplace that specializes in refrigeration or insulation to find it for 1/4" tube size.
https://www.supplyhouse.com/K-Flex-6RX068038-3-8-Pipe-O-D-x-3-4-Wall-Insul-Tube-Pipe-Insulation-61 -
We started selling only linesets with that tough outer layer for this reason. I think these ones below may work for you, thats a good brand anyway if you click the brand name on the website it will show you some other options as well
https://www.supplyhouse.com/K-Flex-6RX068028-1-4-Pipe-O-D-x-3-4-Wall-Insul-Tube-Pipe-Insulation-6
https://www.supplyhouse.com/K-Flex-6RX068038-3-8-Pipe-O-D-x-3-4-Wall-Insul-Tube-Pipe-Insulation-62 -
@EBEBRATT-Ed. That's what I'm going to do. The biggest challenge will be where the lines leave the condenser unit and start up the sheet metal covers. Not sure how I'm going to seal that off with all the insulation and wiring. Thanks.0
Thanks for all the suggestions on where to buy the insulation. I just ordered several 1/4" and 3/8" sticks.0
@JackW
maybe you can find some plastic mesh to shove in there and then spray foam the end and cover it with and end cap as best you can. nothing is 100% but you can slow them down1 -
@EBEBRATT-Ed, I've thought about using foam, but I'm not very good at applying it, plus it would make taking it apart a pain in the butt. Thanks for your help.0
- 120 Geothermal
