Electric Steam Boilers
Phil53
Member Posts: 73
Was reading some of the treads on electric steam boilers and it seems most on here think it will never happen because there is no demand for the manufacturers to make the investment. The NYC thread shows there is adequate demand, but I agree not enough for a company to take a risk. Why not have the government fund the engineering to develop the electric steam boilers? They bank rolled Elon Musk and they paid for all the research for the coronavirus vaccine, why not an electric steam boiler?
Electric steam boilers do exist, and exist in sizes which would be suitable for many residential applications. Demand for them is minuscule because in almost all areas of the country the cost of running one is several times running an oil boiler, never mind gas.
Now the problem arises when we come to the Great Replacement: Unless all the electricity used to power them is "green", they are also worse at converting power at the generating station into usable heat. Indeed, if we are looking at a fossil fuel power plant, three times worse or thereabouts (that is to say, an electric boiler will generate about three times the CO2 emissions that an oil or gas one would. Even the electrify everything crowd gets a bit wobbly when hit with that one.
What doesn't exist -- and would be very nice to have -- is steam generating heat pumps. Technically feasible, but I haven't seen one on the market yet.Br. Jamie, osb
Yes, they do exist have seen them used to steam a sauna and other applications.
In a sauna with no return water the electric elements don't last long due to the fresh water added. But they use them in DHW heaters, and they hold up pretty well0
- 120 Geothermal
