New gas boiler for steam heating
Don10000
Member Posts: 21
in Gas Heating
I am replacing a very old American Standard “Savern” oil-fired steam boiler with a new gas boiler.
I’ve been getting conflicting thoughts about the process of removing asbestos from the boiler. Two Questions please:
1. Does anyone know if the asbestos can be removed from this boiler in the home or does the whole boiler have to be removed from the house?
2. What’s considered a good gas boiler for steam heat?
Thank You!
Thank You!
Posting a few pictures of the boiler, showing it in it's entirety with all piping connected, may get you an answer from someone here.
Also a good shot of the nameplate info.0 -
asbestos removal has to be removed by a licensed abatement company.
weil-mclain, hb smith are some. i used to do a lot with burnham independence boilers but the have problems with corrosion at the top of the cast iron0 -
Peerless, & Weil Mclain are the most popular0
Is that a federal law or a state law?pedmec said:asbestos removal has to be removed by a licensed abatement company.
weil-mclain, hb smith are some. i used to do a lot with burnham independence boilers but the have problems with corrosion at the top of the cast ironSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@ChrisJ
Used to be here that a homeowner could remove it properly at his own risk as long as he took it to the proper site for disposal. Don't know if that is still true.
Probably not the best idea.
I knew a plumber that used to take all his old sinks and toilets (and probably asbestos) and throw it in a dumpster at a post office or a government housing project.
He said that's what he paid taxes for. Maybe not anymore with all the camera's1 -
Are we talking pipe insulation or the actual boiler itself or both.
Might not be a lot of asbestos in a cast iron boiler????
Show it, there are some old timers on here who may have your answer.0 -
The asbestos pipe insulation needs to be removed also, but I'm more concerned with the asbestos insulation inside the boiler. Here is a Pic of the boiler and tag and near piping.
not sure if its the exact same boiler (it looks very much like it) but had it tested for asbestos in the boiler and it came back positive for asbestos. sometimes better to be safe0
Likely places to find asbestos on that boiler:
Air cell board insulation beneath the outer jacket.
Furnace cement sealing joints between boiler sections, and possibly around the fire doors or burner mounting.Vermiculite insulation around the combustion chamber.
Combustion chamber refractory.—
Bburd0 -
Do you have outside basement door/steps it might fit through?0
The boiler would be a tight fit thru two doorways to be removed w/o taking it apart. The easiest way is to take it apart to remove the beast. Not sure, that may cause asbestos to start flying around. Thank you all for your thoughtful replies.0
Is that bat insulation also some sort of asbestos wool?0
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
