Do I need some kind of vent or air separator at this return main high point?
newtonkid88
Member Posts: 104
I was planning on capping off the top tee. But should I put some kind of vent up there? Should it be an elbow instead?
The vertical pipe goes back into the boiler.
The two horizontal pipes are from the return sides of caleffi manifolds.
This tee is the highest point in the basement plumbing, other than the hePex risers from the manifolds going up to the HWBB. All the HWBB have bleeder valves.
There is a spirovent microbubbler air remover on the supply side of the boiler, but it is not at a high point.
In places like that I have put in some means to vent the air manually.
An auto vent is always a potential leaker and sometime lets air in.
You may only need it on initial water fill.
Having a lot of misc fittings myself, I have used a male pipe thread X flare fitting with flare cap....easy to loosen and reseals tight.1 -
Something like this
https://www.lowes.com/pd/B-K-1-2-in-Threaded-Flare-x-MIP-Adapter-Union-Fitting/1000504671
with this cap?
https://www.lowes.com/pd/B-K-1-2-Comp-Cap-LF/5001877617Does the flare end need any dope or tape to seal?0 -
JUGHNE said:Do you have a 1/2 bushing on the top of the tee? Any size will work, for me it is what ever is handy and often used. Flare cap fittings need no sealant for this purpose.0
mattmia2 said:You could also just bush it down to 1/8" and put a coin key vent there.
https://www.supplyhouse.com/Ward-FBHE1x1-8-1-x-1-8-Black-Hexagon-Bushing-754000-p
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
