Bulging Superstor
Member Posts: 4,695
We installed this system in 1997 and the owners have noticed the bottom of the indirect poofing out. I've seen jackets split a lot and can't imagine in any way that the inner stainless steel tank is at fault. Has anyone had experience with this?
25 years is pretty good. Maybe send a pic to Superstore.
Suppose you could cut a section of the jacket and take a look. The only thing I can think of is heat bulging the jacket. But your at the bottom where the tank would be cooler.0 -
It is probably fine, just age insulation deterioration. If it was really leaking it would, I think, be a mess.0
Maybe the seismic support is slipping one way but not the other as it expands and contracts and is pushing on the jacket?0
Like you said, I've seen a lot of split jackets, but never a bulge like that. I wonder if the tank straps effected how the jacket could expand and contract.
I do like the ground clamp on the relief valve discharge pipe.
Sorry @mattmia2, looks like you said the same thing but with a fancy word.1 -
Does this tank need a vacuum breaker and not have one, is the tank getting crushed with a partial vacuum inside under some condition?0
I'm away from the site, but I don't think there's an x-tank on the domestic side because there's no pressure reducing valve or check valve on the incoming water supply. Also, no vacuum breaker.
I think it's like the furniture disease that us old timers get where our chest sinks into our drawers.
Thanks for everyone's comments!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1
- 117 Geothermal
