SpacePak Condensation from Coils Leaking into Pan
mikehvac
Member Posts: 11
I have a spacepak air handler in our finished attic. The coils sweat and some of the condensation drips down to the edge of the cabinet and into the emergency pan underneath. It’s not a lot of water and it never fills up enough to trigger the overflow, but I’m afraid the outer pan will eventually develop a hole. You can see where it drips from the rust in the picture. System works well otherwise and cools sufficiently.
Any ideas on how to resolve?
Where is the condensation -- there will always be some -- supposed to go, and why isn't it going there?Br. Jamie, osb
I would imagine either the copper tubing shown is sweating and dripping on that lip for the door, causing it to exit the cabinet.Jamie Hall said:Where is the condensation -- there will always be some -- supposed to go, and why isn't it going there?
Or, hot attic air is leaking into the cabinet and condensing at that point and leaking out.
Maybe both.
The copper tubing is definitely sweating and dripping on the lip of the door. Any ideas on how to fix?0
Insulate it?mikehvac said:The copper tubing is definitely sweating and dripping on the lip of the door. Any ideas on how to fix?
Move it?
Build a small tray to catch the water and run it inside?
I don't know.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
mikehvac said:The copper tubing is definitely sweating and dripping on the lip of the door. Any ideas on how to fix?0
SpacePak is pretty good equipment. Therefor... at one point it must have been set up so either that copper tubing didn't get chilled or, as @PC7060 implies it was placed so that any drips that formed on it would go into a pan designed to catch it. I would move the tubing if I could -- but I think I might also check and be sure that I have the proper refrigerant charge and pressures and that the equipment really is working properly.Br. Jamie, osb
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
