New Tool
Aren't there o-rings that can be replaced in those?0
Perhaps, but I couldn't even remove the valve. It was pretty rusty and deteriorated at the leak point and the flats rounded out immediately.
Also, the manifold is on the second floor of a $7M house and I can't take any chances with a leak.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
You could have bought a manual expander like I use.I was looking forward to finishing my career without having to purchase any more expensive tools, but that won't happen just yet as a job this week required the replacement of an old Wirsbo manifold. It seems that they don't make replacement valves for these manifolds any longer and this one was leaking from one of the outlet valves and with the way this manifold was installed, I had to re-work the 1" PEX to connect the new return manifold. If any of you are in the area and need a Milwaukee M18 expander tool, let me know.
Those M18's are steep.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
I wouldn't want to do more than one or 2 of the 1" at a time with the manual tool but it does work if you manually rotate it.0
I've heard rumor this guy used to do a lot of 3/4 and 1" with a manual expansion tool.
But like you said, for one or two joints, you'll manage.
Do those power heads still work? They are pretty notorious for breaking right at the base.
I won't even ask why there is teflon tape on those compression joints
Rick0 -
@rick in Alaska I don't know if any of those work. Once I repair the manifold, it will be time for testing them all. A lot of them are busted.
Also, all of the knurled nuts that secure them to the manifold are loose. Maybe they did that over time?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Not sure if you know this or not, but you don't tighten the nuts down all the way when you install them. You tighten them down until the pointer in the indicator window is centered in the window. At least that was how I was taught.
Rick
@rick in Alaska @Alan (California Radiant) Forbes
Those are a PITA, not because of how they function, but the replacements
I do believe that if you are planning to replace those telestats the new ones don't come with the correct adapter. Try one of this part number before you order all the supplies, you should be able to use the current 2 or 4 wire telestats with this adapter. I usually have a little key ring with all of them so that the service guy can confirm which spacer ring to use.@rick in Alaska I don't know if any of those work. Once I repair the manifold, it will be time for testing them all. A lot of them are busted.
A3019900 VA33 spacer ring Uponor local uponor supplier might not have these on hand, it's a pretty rare occurrence that I need them
A3023522 4-wire uponor telestat
I have had horrible luck with the adapters and the new telestats. I can get like one full turn with the adapters, and almost impossible to get the telestat locked on, and keep it on. My last job I just changed out the manifold to a Rehau and went with all new telestats.
Rick0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
