Uponor metric manifold connectors
Alan (California Radiant) Forbes Member Posts: 4,640
edited July 2022 in THE MAIN WALL
We are replacing an older Wirsbo manifold that has metric tubing and want to replace some of the connectors. Does anyone have any or know where to get them? They’re smaller than 3/8”; more like 1/4”, so it’s got to be close to 6mm. Even a part number would help me to search for one.
Thanks!
  • don123
    don123 Member Posts: 51
    SKU
    A4020313 maybe this from supply house.com
  • That just may be it. Thank you!
  • don123
    Others have helped me! I hope I helped you, let me know.
  • GGross
    GGross Member Posts: 1,733
    Generally you would see that 5/16" tubing where the wood panel quick track is used. If that's the one it's a common fitting and your local Uponor supplier should have them on hand
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,313
    I was thinking the same thing, the 5/16 tubing that was around early on and in panel trak.
