Uponor metric manifold connectors
Member Posts: 4,639
We are replacing an older Wirsbo manifold that has metric tubing and want to replace some of the connectors. Does anyone have any or know where to get them? They’re smaller than 3/8”; more like 1/4”, so it’s got to be close to 6mm. Even a part number would help me to search for one.
Thanks!
SKU
A4020313 maybe this from supply house.com0 -
That just may be it. Thank you!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I was thinking the same thing, the 5/16 tubing that was around early on and in panel trak.GGross said:Generally you would see that 5/16" tubing where the wood panel quick track is used. If that's the one it's a common fitting and your local Uponor supplier should have them on hand
To learn more about this professional, click here to visit their ad in Find A Contractor.0
