Magical mystery fitting
SVDW
SVDW Member Posts: 80
This is installed on 2” DHW  line in a school built in the 50’s. No rating plate or rivet holes where there ever was one. Anyone have any idea what it might be? My guess so far is a thermosiphon recirc device or an exp compensator. Smartest piping guys in the world are on this forum.  Any of you seen this before? Thank you for your time!
  • JUGHNE
    JUGHNE Member Posts: 11,508
    edited July 2022
    Strainer/filter???
    It would have most likely been plugged by now.
    Maybe the guts are out of it.
    Zman
  • PC7060
    PC7060 Member Posts: 1,750
    check valve?
    JUGHNEdelta Tmattmia2
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,989
    edited July 2022
    Hi, it could be something unusual like magnetic water treatment… I think the only way to know for sure is to take the unions off, unbolt it and see what’s inside.
    Yours, Larry
  • Big Ed_4
    Big Ed_4 Member Posts: 3,338
    Check Valve upstream from the fire hydrant system ?
    EBEBRATT-Ed Member Posts: 19,349
    Looks like maybe a packing joint on the left side. I would think it is an expansion device
  • PC7060
    Open it! Open it!  :D
    mattmia2kcopp
  • rick in Alaska
    rick in Alaska Member Posts: 1,510
    I'm wondering if it is a flow restrictor? Is the packing gland on the side because it is set up like a dresser coupling for the copper pipe?
    Rick
