Dead Men Tales: How One Missing Pipe Can Make All the Difference
HeatingHelp
Administrator Posts: 718
In this episode, Dan Holohan shares the solution for a common problem in areas where contractors add hot-water zones to steam boilers.
Thank you to SupplyHouse.com for supporting this podcast.0
Most times I get stuck on a troubleshooting job it's because i assumed something when I shouldn't have. When things don't make sense it's time to go back to ground zero and look at everything with an unjaundiced eye.Smith G8-3 with EZ Gas @ 90,000 BTU, Single pipe steam
3PSI gauge0 -
I would ask myself, What is undeniably true? And then I would ask, What are all the things that can cause that?
There is definitely water hammer happening.What can cause that?That forced me to look beyond the steam.Retired and loving it.0
