Ruud Water Heater Repeated Gas Valve Failure or Wider Problem?
I have an approximately 8 month old Ruud PROG40 38N RU62 water heater. This replaced a 10 year old water heater that could not maintain water temperature. It worked great for about 6-7 months, then stopped being able to maintain hot water temperature. Plumber replaced gas valve, which includes basically all replaceable parts, including thermostat. Heater then still could not maintain hot water temperature, on A setting (130 degrees) water temp was 110. Plumber again replaced gas valve, immediately after replacement A setting was 130, but next day, no hot water at all. As this point I am trying to figure out if (1) Ruud gas valves are uniformly defective, (2) some other problem exists in the Ruud heater outside the gas valve or (3) outside conditions, like the water or water line or gas or gas line are causing the problem. We had our gas line changed from low pressure to intermediate pressure in the past year, for example. Everyone is mystified any suggestions?
1
VERY interesting and unusual! I haven't a clue.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Hi, Thermostats can fail if buried in sediment, but it's rare. If you had softened water and an aluminum anode in the tank it could cause this sort of problem. If the hot and cold lines were reversed, that could cause trouble as well, but it might not show up until there was more hot water use. Sometimes the dip tube is missing. All that said, I'd ask Ruud directly if there have been problems with their gas valves.
Yours, Larry2 -
Thanks! Looking at the heater it looks like the pilot is out. Which obviously is the immediate source of no hot water, but this is a one day old gas valve!0
I think the gas pressure comments are well taken, this is definitely going to be looked into.0
@chriswar
I may be pretty cynical in general. I usually just assume when someone tells me "the gas pressure is fine" or some variation thereof, that they did not check the gas pressure. They should be able to give you an exact number, and show you that it falls within the specified range.
2 -
I had a an issue with an atmospheric water heater in which the pilot went out several times. I also threw parts at it which did not fix it. I believe what fixed it was tightening the connection of the flue to the chimney and tightening the chimney clean out door. I'm not an HVAC pro and this is just one heater in one building. Just sayin'1
Did the gas company upgrade the pressure on their side of the meter or on your side of the meter.
If on their side only then their regulator may not be delivering enough consistent pressure.
Pilot outages are often a possible sign of low delivery pressure.
If your side of the meter/regulator was upgraded then you might have a new regulator at each appliance.
It takes maybe 10 minutes to check the pressure at the gas valve......if you have the right tool......1 -
Same problem with my 50 gal RUDD water heater. After 10 months, no hot water. The heater repair guy replaced the gas regulater, but the gas flame still wouldn't stay lit. He also said gas has been leaking "for awhile"....yikes!
They're getting me a new water heater today, but I don't want a RUDD again.0
- 120 Geothermal
