Lochinvar Noble Combi internal piping question
In_New_England
Member Posts: 166
The Noble install recommends a secondary loop system for space heating (as I believe a lot of other boilers do). Water from the main heating loop is split (closely spaced tees) and there is a pump in the boiler that draws water into the heat exchanges and then returns it to the main heating loop.
For a domestic heating call, does the same, secondary loop, operate to move heat from the fire tubes to the domestic hot water heat exchanger or is there a second internal loop inside the boiler that we can't access from the outside?
Thank you.
Thank you.
There is an internal diverter and heat exchanger to handle DHW. Just pipe the domestic side like shown in pages 45=49 and you should be good to go. https://s3.amazonaws.com/s3.supplyhouse.com/product_files/Lochinvar-NKC110N-Install.pdf
This one shows the internal parts https://s3.amazonaws.com/s3.supplyhouse.com/product_files/Lochinvar-NKC110N-Replacement.pdf
Albert Einstein1 -
- 50 Industry Classes
