Toilets: We (Almost) Don't Need Them Anymore.
Member Posts: 4,547
There's been a lot of toilet talk here recently. This is a novel idea that could go places.
Interesting this subject comes up here. Definately not a new idea, I consider this old world knowledge. Older than steam.
It gets a little unsettling that humanure is reviving, sometimes people run the wrong way with ideas from the internet.
Thinking things through:
- some rural areas, septic waste is directly spread on farm fields and is turned in.
-"Compost" from home centers come from municipal waste byproducts sold to suburban back yard gardeners (labeled as "organic" to make you feel good).
In some aspects, this is how the world goes round.
I'll be in the garden.0 -
"Toilets: We (Almost) Don't Need Them Anymore." Are Diets that good now ?
My friend's Leach Bed (or Leach field) heats up the lawn and melts the Snow, so far he does not need help with that heating system.National - U.S. Gas Boiler 45+ Years Old
One Pipe System0 -
Is that supposed to happen in the septic tank?0
I'm thinking the warmed air from the whole process dissipates out into the Leach Bed (or Leach field) heats up the lawn enough to melt a light Snow.mattmia2 said:Is that supposed to happen in the septic tank?
One Pipe System0 -
Amusing. Milorganite is probably the best known trade name for sewage sludge sold as compost/fertilizer, but there are others. Assuming that it is domestic waste water that is the starting point, it's not all that bad (although there is some concern about some drugs that make it through -- antibiotics particularly, but some hormones). I know of at least two ski areas which use tertiary treated waste water in the snow making process (I helped design them -- and no I won't name them... don't eat the yellow snow). Tertiary water is also placed in lagoons for groundwater recharge in places; I believe Phoenix does this. Secondary or tertiary water is also perfectly good for irrigating lawns and some crops (not crops which get wet -- such as lettuce or rice for instance) or for use in toilets (the problem there is the extra plumbing).
Some jurisdictions do allow land spreading of sewage sludge (mostly from aerobic digestion -- anaerobic sludge has ... shall we say a noticeable odour? It's a good soil amendment -- but it's a miserable fertilizer (not enough nutrients left).
Composting toilets work well enough, though they do require attention, and are a good bit safer than a privy. But no more suited for heavy use than a privy.
A carefully designed septic system can approach zero effluent, even in fairly northern climates. Unfortunately there, most such systems are designed on the "out of sight, out of mind" principle, which does create a groundwater contamination (primarily nitrates and phosphates) problem.Br. Jamie, osb
My leach field would show through after a light snow. I took pics of it to help remember where all the leach lines were run. I suppose just hot water after shower, laundry, dishwashing would warm the field. As winter progressed the "stripes" would go away.109A_5 said:
I get a few sewer and pumper magazines, my wife is in that business. It is a huge concern now with medications and illegal drugs in the systems. Even after running through the body there is still some residual.
I have secondary irrigation water and somedays it smells like a Tide Pod, depending on who is dumping treated sewage upstream, I suppose?Bob "hot rod" Rohr
No, no, we definitely need toilets.
If you disagree then you're not welcome in my home.
The article is mainly about the use of urine - which is sterile, except for some bacteria - on crops. It doesn't need to be composted and can be used full strength on soil that is already wet.
I'm sure there are drawbacks, but it's a novel idea if it's only for your own vegetable garden.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I'm going for pee to power, with or without the weed "boost"Bob "hot rod" Rohr
@Jamie Hall , as a longtime gardener I too would have some concern about the antibiotics and hormones that are excreted in urine - although if used on ornamentals rather than a vegetable garden, probably no difference.
Of greater import, from a plant-health perspective, is probably pH. The pH of urine can be anywhere from 4.6 to 8.0 and still be within normal. That's a really wide range. I wonder if the commercial users are changing the pH to something approaching neutral before they apply it.0 -
So peeing on the hosta's to keep the deer away has other benefits too? :P0
I'm still not clear on what you mean by "just fine" ?109A_5 said:
We may not see 100% electrification in our lives, maybe ever. But it is clear that the horse has left the barn on the path towards electrification globally. A renewed focus with world events recently.
I'll come down on the side of those looking forward to innovative solutions.
Certainly doesn't hurt that our industry plays a big part in this, and can even bolster the hydronics side of us with A2WHP options.
The DOE recently awarded 61 million to 74 nuclear energy projects across the country.Most goes to research at universities in 29 states. So the next generation can continue to work on safe, reliable energy options. While most of my generation may not be comfortable with nuke plants I have faith in the younger generation to find way to bring "power to the people"Bob "hot rod" Rohr
Living the hydronic dream1 -
Marjorie Wildcraft The home gardening expert states that urine should be diluted with ten parts of water before using it to fertilize crops.
I am concerned aside from drugs in wasted water is the possibility of heavy metals. the selling of sludge to farmers solves the disposal problem for sewage producers. Kinda like, selling stannous fluoride to the toothpaste producers, a waste disposal solution. Natural occurring fluoride is calcium fluoride.
When we don't have food to eat or potable water to drink, will we need toilets except to flush spiders down? A prudent strategy shorting Kohler and AmStd stock? hmmm
Disclaimer: I am not now or ever have been a licensed financial planner. Any financial statement in this comment is for informational purposes only and is not to be construed as financial advice.1
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
