Anyone know where to get 1 1/2 inch left hand thread pipe plugs?
The Steam Whisperer
Member Posts: 1,315
Could use some for old radiators.
mcmaster-carr?0
Looks like a left-right nipple and a cap might be the most commonly available solution.0
Unless you have a machine shop make some.$$$$0
Is the radiator itself left hand thread or is there a bushing in the radiator that is right-left that was used to couple 2 radiators together or make up a fitting with a return without a union or something that could be removed and replaced with a larger right hand thread plug?
I wonder if there are shops in china with CNC machines that you can send a file to for fabrication cheaply the same way you can send printed circuit boards.0 -
I use a cap and 4” nipple or i cut the nipple just past the left hand threads and weld a disc onto the cut end.0
- 50 Industry Classes
