Anyone know where to get 1 1/2 inch left hand thread pipe plugs?
Could use some for old radiators.
    mattmia2 Posts: 17,992
    mcmaster-carr?
    Looks like a left-right nipple and a cap might be the most commonly available solution.
    EBEBRATT-Ed Posts: 20,937
    Unless you have a machine shop make some.$$$$
  • ChrisJ
    ChrisJ Posts: 17,645
    Depends on how many you order.
    Is the radiator itself left hand thread or is there a bushing in the radiator that is right-left that was used to couple 2 radiators together or make up a fitting with a return without a union or something that could be removed and replaced with a larger right hand thread plug?
    I wonder if there are shops in china with CNC machines that you can send a file to for fabrication cheaply the same way you can send printed circuit boards.
  • JimP
    JimP Posts: 109
    I use a cap and 4” nipple or i cut the nipple just past the left hand threads and weld a disc onto the cut end.
