New boiler question
Ultra2424
Member Posts: 5
We had a new high efficiency combi-boiler installed, an NTI TRX 150C. It's for radiant floor heat and DHW using natural gas. Does the boiler turn on ONLY when there is a call for either DHW or radiant heat?
So far we love the boiler and it's efficiency. Also this forum is by FAR the most helpful and courteous people of any forum/website I've ever been on. Thank you!
3
With no call for heat or DHW it should be off0
I have a NTI TRX 150C that is keeping the internal temp at 130 deg. continuously.
DHW comfort setting is "OFF"
Any thoughts on why the boiler maintains 130 deg when no call for heat or DHW?
I appreciate any help on this.0 -
@db2022 the boiler may have a setting to keep the DHW side warm.0
@db2022 If you haven't already done so, get into the programming and cycle through the values for the DHW COMFORT function to end up with a value of "0" - deactivated.
Page 72 of the manual here.
If that doesn't solve the problem, call NTI technical support.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Thank you for your suggestions. I'll try to dig a bit deeper in the tech menu. I had selected comfort "OFF" in the home owner menu and had confirmed it's setting as "OFF". Holiday weekend here in U.S. So a call will have to wait until Tuesday.0
It may be good to turn it off and on again and make sure setting of "off" took.Tom
Montpelier Vt0
