Heated Floors
wre
Member Posts: 1
We have heated floors in our bathroom. They have WIRSBO motorized valve actuator. We have it off but the floor is still very hot (hotter somedays then others). Any suggestions? Do we call a plumber or an electrician?
When you take the motorized actuator off, doesnt that open the valve ?
When you install the MVA, it pushes the pin down and closes the valve. When the motor runs, it releases the valve to open.
The room was overheating before you removed the MVA ? Its either a control problem telling the valve to open, or the MVA is broken internally. My MVAs started having issues at about the 10 year mark.. usually the end switch, but some of them broke internally.
Depending on the valve/manifold type, you might be able to manually close the valve off by screwing down the valve body (the pin is just the topside of the valve) goes down with it. On mine (old type Wirsbo round manifold), I have black caps that fit over the pin upside down.. it fits in little slots to enable me to turn clockwise and shut the valve manually.
Currently in building maintenance.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
