Need someone in Somerset county NJ to replace two rotted sections of wet return line
sbelyo
sbelyo Member Posts: 15
Hi All...
Need someone in Somerset county NJ to replace two rotted sections of wet return line. They're each about 12 inches long and are accessible. It appears to be 1-1/4 inch line
Thanks
Steve
    Jamie Hall Member Posts: 27,312
    Replace the whole section of pipe -- don't just patch or splice the rotted sections. I expect @EzzyT or @clammy might be available -- click on the names there to send them a personal message.
  • sbelyo
    Thanks, I'll send them a message. Didn't know how easy it would be because of the length. I'd say it's 25 feet total in length.
    It's worth doing, though. Generally if there is one rotten spot -- never mind two -- there are others just waiting to jump at you.
    kcopp
