Converting existing boiler from oil to propane
MaxMercy
Member Posts: 552
in Oil Heating
Hi, I was wondering for future consideration the feasibility of converting an existing boiler to LPG. I have a 2 year old Slant Fin Intrepid TR30 that is running an AFG. As of this morning, heating oil is $6 per gallon. I don't know where oil will go from here but I'd like to consider some options for the future.
Quick searching shows a Beckett CG4 burner which has the same form factor as an AFG,which means it will physically bolt right up to the Slant. Such a burner would mean I wouldn't have to replace a fairly new boiler with a gas-dedicated one, but what kind of efficiency does a gas conversion burner like this Beckett CG4 have compared to a typical gas boiler that was built specifically as a gas appliance?
Thanks.
Thanks.
It depends on the specific boiler design, but in general boilers with forced draft can be more intricate and extract more heat than natural draft appliances.0
If the boiler manufacturer allows the conversion in question with the specific burner in question, then you are fine. i don't know if that one does. However, before you leap from the frying pan into the fire, consider that for oil at $6.00 per gallon LP must be less than $9.33 per gallon to break even on the fuel cost.Br. Jamie, osb
I wouldn't, but Beckett has a spec...
And a Carlin gas burner will work as well.
The efficiency on gas will always be a couple of points less than an oil burner (we are talking 1-2%). Gas in any non-condensing boiler is always slightly less efficient than oil due to the water vapor in gas.
If the gas price is right, it will make up for that if your talking natural gas.
Summer is almost here. I would wait a little bit and see if oil prices come down. You would hate to have the conversion done and then regret it0 -
Whoops. Missed the fact your talking propane I doubt it would be worth it.0
Propane also has less hydrogen content than methane but still more than oil.EBEBRATT-Ed said:Whoops. Missed the fact your talking propane I doubt it would be worth it.
Intrepids run great with Carlin gas burners- Midco EC burners too.All Steamed Up, Inc.
Consulting0
