ignition problems with funace
Julius_1
Member Posts: 2
in Gas Heating
Hey guys, what can cause ignition problems? My funace in sauna didn't switch last weeknd. We have already turned off the heating, but our basement radiators work fine (we have it on all year), so the gas line is fine. What can I check, so that before I call a master, at least to understand what is out of order?
And also suggest some masters in Tennessee, around Chattanooga, THANKS0
issues with- Power, air, fuel, spark, incorrect wiring, and defective or broken parts can all create ignition problems. You can not determine that there is no issue with the gas just because another appliance is running fine on the same fuel lines. You need to contact a licensed service company, use the contractor locator on this website to find trusted professionals.0
Your description is somewhat confusing. You say a furnace heats the sauna, but a boiler the basement? Is that correct or are they both heated from the boiler?
Some pics would help.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
