Raypak 055b Thermostat
EricAiken
Member, Email Confirmation Posts: 1
I was curious if someone might know where I could find some technical specs on a raypak 055b thermostat (600885). They call it a unitherm governor. @ $75-100 buck that's just crazy, its just a thermostat. if I could find it's operating temperatures, I could find an alternative. Perhaps you have a lead on a reasonably priced one somewhere.
Thanks in advance
Thanks in advance
You may be able to find the specific part here: https://www.supplyhouse.com/Raypak-Parts-29560000?utm_source=bingad&utm_medium=dsa&msclkid=b433615a200c1f302a29030a56aa56dc
There are several thermostats, and none of them are "just a thermostat".Br. Jamie, osb
That’s a pool heater isn’t it? I suspect that control keeps the boiler from running in condensing mode. No doubt an OEM part
https://poolsupplyworld.com/047696bc-e540-4f99-8cc9-0249aaa65436.html
Living the hydronic dream0
- 116 Geothermal
- 169 Indoor-Air Quality
