Bell trap best bet?
I have an untrapped floor drain (with the associated stink). I'm thinking of installing a bell trap drain with a push fitting into the existing vertical clay pipe. I was wondering if there were any better solutions I should consider before proceeding to chip up the floor.
This
plus this
This
plus this
I'd be very careful with a compression donut & clay pipe.
Have you considered breaking up the floor and installing a standard p trap & a trap primer? A lot of work, but a permanent, reliable, and long lasting solution......0 -
Either a donut or an external compression fitting. Too much hassle to put in a p trap. Anyone have a link to Fernco dimension drawings? 4"+/- ID to 3" no hub. They do list a 1002-43 for cast to clay (external)
Bell traps are not approved by most codes. You may want to try this...
https://rectorseal.com/sureseal-waterless-inline-drain-trap-seal-group/
That's nifty! Thanks!Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
- 120 Geothermal
