Honeywell Zone valve Header or Diaphragm?
Danscrew
Member Posts: 130
I’m looking for the internal zone valves inside this header need a P/N or a link on where to get them thanks Having
a tuff time locating them Thanks for everyone’s Help Dan
It looks like that white heat motor is the replacement.0
Looks like this crosses to the right part eventually. Looks like there may be a thread adapter ring too:
https://www.supplyhouse.com/Wirsbo-Uponor-A3020522-Motorized-Valve-Actuator-MVA-four-wire-2062000-p0 -
I think the original were Sparco, then Honeywell Sparco. Wirsbo also used them. I think they all interchange
The other looks like a Caleffi TwisTop. A great replacement if it opens and closes completely?Bob "hot rod" Rohr
I appreciate everyone's input I found a Caleffi P/N 656354 that works as Shown in pic. What I need is the internal valve actuators on the inside? Thank you to all0
