Honeywell Zone valve Header or Diaphragm?
Danscrew
Danscrew Member Posts: 130
I’m looking for the internal zone valves inside this header need a P/N or a link on where to get them thanks Having
a tuff time locating them Thanks for everyone’s Help Dan
    mattmia2 Member Posts: 16,092
    Are the honeywells motorized valves and the 3rd one a heat motor? Is there a part number on the honeywell actuators?
    heathead
    It looks like that white heat motor is the replacement.
  • Solid_Fuel_Man
    They sure look like Wirsbo/Uponor units rebranded as Honeywell. Or maybe that is the other way around!
    Looks like this crosses to the right part eventually. Looks like there may be a thread adapter ring too:
    https://www.supplyhouse.com/Wirsbo-Uponor-A3020522-Motorized-Valve-Actuator-MVA-four-wire-2062000-p
    hot_rod Member Posts: 27,116
    I think the original were Sparco, then Honeywell Sparco. Wirsbo also used them. I think they all interchange
    The other looks like a Caleffi TwisTop. A great replacement if it opens and closes completely?
  • Danscrew
    I appreciate everyone's input I found a Caleffi P/N 656354 that works as Shown in pic. What I need is the internal valve actuators on the inside? Thank you to all
