Water pressure
If you look at page 35 in the manual you will see a screen on the inlet. It's probably clogged.
https://www.weil-mclain.com/sites/default/files/field-file/Weil-McLain_AquaBalance-Series2_Manual_550100325_0419b-web.pdf"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1
- 50 Industry Classes
