Radiator Clang. What causes it?
BirchLeaf
BirchLeaf Member Posts: 56
Hello,
What causes steam radiators to make occasional clanging noises?
(It's a different sound than the loud banging of steam coming in contact with water.)
Thank you.
    EBEBRATT-Ed Member Posts: 15,568
    Water or the radiator expanding. something slippery under the feet like pieces of a milk bottle. or the pipe could be rubbing if the hole in the floor is too small
    BirchLeaf
  • BirchLeaf
    @EBEBRATT-Ed
    Expanding from heat entering the radiator?
    yes
    BirchLeaf
  • retiredguy
    retiredguy Member Posts: 911
    If the valve has a flat disc, the disc could have come loose or has broken off from the stem.
    BirchLeaf
