Triangle Tube Prestige 60. Can't remove Phillips screw on back right of blower
Danielg9
Danielg9 Member Posts: 1
I need to remove the blower to access the heat exchanger on my TT60. I can't remove the blower because one Phillips screw located on the right rear has only half inch clearance. I've tried a Neiko flat Phillips and a 90 degree Phillips but can't grab the screw. Any ideas.
  • Shane_2
    Shane_2 Member Posts: 200
    I thought they were torx, T25? That said, if the long screwdriver included with the new blower doesn't work, I have used tips from my screw gun set with a 1/4 ratchet or with 1/4" ratcheting open-end/spanner
  • Tom_133
    Tom_133 Member Posts: 957
    I believe Shane is correct. The long screwdriver, you need to slide it down between the motor of the blower and the housing. Its almost a straight shot at it.
    Tom
    Montpelier Vt
    Derheatmeister
  • tim smith
    tim smith Member Posts: 2,886
    some were phillips on older units, now torx if memory serves me.
    Zman
