Triangle Tube Prestige 60. Can't remove Phillips screw on back right of blower
Danielg9
Member Posts: 1
in Gas Heating
I need to remove the blower to access the heat exchanger on my TT60. I can't remove the blower because one Phillips screw located on the right rear has only half inch clearance. I've tried a Neiko flat Phillips and a 90 degree Phillips but can't grab the screw. Any ideas.
I thought they were torx, T25? That said, if the long screwdriver included with the new blower doesn't work, I have used tips from my screw gun set with a 1/4 ratchet or with 1/4" ratcheting open-end/spanner0
