Solar water panel ID?
There should be a tag like this on each collector.There are so many manufacturers come and gone. Many if not most bought the copper absorbers from AET in Florida. Those look like the ThermaFin absorbers from AETBob "hot rod" Rohr
Living the hydronic dream1 -
Hi @Orion_134 , I'm half guessing, but the collectors look like they have a black chrome coating, which was/is top of the line. I'd figure out what fluid was circulated through them as it could help to know what potential corrosion issues might be. I'd have a close look at the lower ends of the collectors to see if there is evidence of internal leaks. Also look at the headers to see if there is any swelling or evidence of leaks where the finned tubes connect. The collectors are copper and can be fixed, but it's a silver solder job, after the glass is off, and you don't want to burn up the insulation either
... What are you thinking of doing with the panels?
Yours, Larry0 -
Top of the line. I like the sound of that 😂. I'm just wanting to get more info about them, like capacity and lifespan and such. The system appears to be a pressurized glycol system that has had regular maintenance performed.
Thanks for the tips, y'all. I'll get back up there and look again for a tag as well as check those areas.0 -
The older collectors like that had a much heavier gauge of copper, both the fin and tube. Properly cared for they can last 30 years or more
Keeping an eye on glycol is important, check the ph yearly, boost if necessary, flush it if it drops into the 7 ph range. Invest in a ph meter.
Prevent over heating, stagnation conditions that destroys the insulation and can cloud the glass from outgassing. Frequent over heating stresses the braze joints also
The Isolar control has several over-heat functions built in to protect collectors, read up and enable themBob "hot rod" Rohr
Living the hydronic dream0
- 15.8K Strictly Steam
