Shortage of Gorton Vents
I just logged onto Supplyhouse.com and saw they have a very limited supply of radiator vents. Is there now a shortage of these vents on the market along with everything else?
    mattmia2 Member Posts: 16,080
    are they shown as backordered or just out of stock? a lot of stuff they don't stock but can get quickly.
  • Pumpguy
    Pumpguy Member Posts: 794
    Hopefully @mattmia2 is correct and they can get them quickly.
    That said, I am finding that so many accessory hardware items for steam heating systems and related pumping equipment is not in stock and has a long lead time.
    Case in point is a mechanical alternating float switch I have on order from Supplyhouse.com. Same story, no stock and uncertain lead time.
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    I assume you're looking at the ⅛" angle radiator vents, because they have a lot of the straight ones. The only angled one they're showing is the #6, and they have 60 of those. The thing that strikes me as strange is that they usually show an item as backordered when they run out, like this: https://www.supplyhouse.com/Hoffman-401422-1A-1-8-Adjustable-Angle-Steam-Radiator-Air-Valve-3516000-p
    Maybe you should ask them what's up with that.
  • Dan_NJ
    Dan_NJ Member Posts: 268
    Interesting, after my experience with Gorton 2 years ago where I ordered 2 of them and one was a fail right out of the box, and combined with recent similar comments on their failure rate, I wonder if they've got other problems and not just supply chain issues.
