Radiators on top floor not heating up
Emcgreeny
Member Posts: 1
I live in a 3 story house and the radiators on t he top floor have stopped heating up, I’ve bled them and topped up the water pressure on the boiler but they are still not heating up any suggestions?
how many zones?
valves or circulators?
post pictures,
did you bleed with the circ on? or off?known to beat dead horses0 -
How many thermostats on the top floor? If only one, it could be that a pump or zone valve or the thermostat itself is bad. If more than one thermostat, there are more questions to be asked.
Even thought you've bled all the radiators and the pressure is fine, there might still be air in some of the horizontal pipes or stuck at a high point in the system.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
More Questions:
When you bleed the radiators, does water come out ... or only air? (insufficient pressure in the boiler)
Are the other radiators heating properly?
Is this something new? or has this always been the case?
Did anyone do some work (unrelated to the heater) in the home around the time you started to experience the problem?
for example: I remember a customer's child needed batteries for his GameBoy and knew that mom just put new batteries in the thermostat. I got a no heat call the next day and charged for a service call and 3 new AAA batteries. GameBoy is unrelated to the heater = very expensive batteries
Cable repair, electrician, bug exterminator, anyone may have inadvertently touched a switch, broke a wire or bumped a valve.
Pictures and more info about the system please?Edward Young Retired
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
