EK system 2000 hot water tank fail
Juggatweet
Member Posts: 11
I've got an Energy Kinetics system 2000 and the hot water storage tank leaked water all over the floor. I need to determine if it's better to replace it or just buy a separate electric hot water heater. Any help is appreciated!
No warranty it was not transferred by the original owner. I Got the replacement tank ordered. What things can I look for to know why it failed? And why do I want to test my water. Sorry I'm not familiar with any of this and the why helps me understand.
Another thing to consider is that anything that affected you storage tank also affects your heat exchanger. EK says to backflush the heat exchanger fairly frequently if you have water issues. https://www.hannabery.com/how-to-backflush-plate-exchanger-hot-water-heating-system.shtml
Hi @Juggatweet ,Things you can do to understand why it failed... Here's a short list. Get a water quality report, so you know about the water, whether it's aggressive, acidic, or hard. Measure static pressure. It's easiest on the tank if it's between 40 and 60 psi. Is there provision for thermal expansion? If not, you could be getting pressure spikes. Get a pressure gauge with the little red indicator built in. This will show you what the highest pressure seen by the plumbing is. Have a look at the anode in the tank (if there is one) and let us see a photo. If you pull out just a plug, it was long since used up and should have been checked more often. Look at all fittings on the tank. Did any leak or seep? If so, that water could have eaten through the tank from the unprotected outside.
Yours, Larry3 -
Thank you for your post on this, @Larry Weingarten , that's great information. @Juggatweet , Joe in our tech support group PM'd you earlier, let us know if we can help further.
Best,
RogerPresident
Energy Kinetics, Inc.1
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
