Help To Identify Old Radiator
canada
Member Posts: 1
Hello...
Can anyone identify the radiator in the attached photos?
(Manufacturer? Model?)
The building was constructed in 1896 and is located in St. John's, Newfoundland, Canada.
I've already reached out to a company that restores old radiators and they've never seen this style, nor is it listed in any of the manufacturers specs they have for US radiators.
Thanks
Thanks
Thanks
Thanks
1
Neat. I've seen ones rather like it, but I couldn't tell you the manufacturer. What do you need done to it?Br. Jamie, osb
It looks like a hot water radiator, not steam. Just curious.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
It's some sort of "flue" radiator. Look at the area around the pipe connections at the bottom, you might find the name there.All Steamed Up, Inc.
Consulting0
- 120 Geothermal
