How much would this cast iron radiator weigh?
eclecticmn
Member Posts: 129
Radiator is 5 tubes, 8 inches wide, 20 high, 25 sections (5 feet long).
Is there a source with weights of radiator sections?
How would you move such a radiator? What equipment and how many people?
Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.
Couple of hundred pounds, easy.
How you go about moving it depends on how far you plan to go with it -- and whether it is up and down or all on one level. What I've done for going any distance at all is lay it on a hand truck -- a sturdy one -- on its side. If it's all on one level, one could also use a good big furniture dolly. Strap it on well -- actually, using an appliance truck with the built in strap is a good idea if you have one. Going up and down stairs is quite doable, just ease it down a step at a time. Not a bad idea to have someone tailing onto a rope. Never EVER let someone be below the truck. Going upstairs will be a LOT easier if the hand truck has stair climbers on it. Either way may take the effort of two or more strong people...Br. Jamie, osb
2 guys with straps and harnesses if there are stairs involved. Else like Jamie says.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
5 feet long! I'll bet 4- 500 lbs. easily
From some older posts.
What @delcrossv said.delcrossv said:2 guys with straps and harnesses if there are stairs involved. Else like Jamie says.0
