Logstor fittings
Matt_67
Matt_67 Member Posts: 313
Does anybody have a good source for Logstor fittings? I'm working on a project where the underground piping is installed and its 32mm pex. So far I haven't gotten response from the rep and I haven't been able to find any online either.
    hot_rod Member Posts: 27,472
    PE geo tube is 1.315 od.
    32mm is 1.26, so I think the common geo grip fittings will work. He is a version we offer from Caleffi.
    Is this for a wood boiler? if so the temperature rating of the fitting is important. I'm not sure plastic GEO compression fittings would work?
  • Matt_67
    edited February 2022
    It is for a wood boiler - it’s a wood chip boiler for a small 6 building campus. These fittings would be 15 to 20 feet from the boiler but it would be good if they could take higher temps. The logstor pipe is good stuff - kind of frustrating not to be able to find proper fittings for it.
    Can the brass Caleffi fittings take the heat? If so would you have a part number?
    Quite a few dealers show up when you Google Logstor, in the US and Canada. Are their fittings not available.
    The ones I have are 34 mm. We do make 32 mm, but they are a Euro product.
  • Matt_67
    I'm getting a lot of "pound a 1 inch hose adapter into the pipe and put some hose clamps on it". I see availability of 32mm pex-al-pex fittings but of course the ID is different. I'll need 28 of them on this project so I'm really hoping to source the right fitting if possible. I get the feeling they are expensive and the dealers would rather not stock them?
  • GroundUp
    GroundUp Member Posts: 2,513
    The correct Logstor fittings are compression like Hot Rod shows, but the availability is near zero from Urecon dealers. I got tired of it a few years ago and started using regular 1-1/4" pex crimp fittings with doubled copper crimp rings. Slide one ring on, gently heat the Logstor with a torch and push a 1-1/4" pex x male adapter in it, crimp the ring, then split a second ring with a side cutter and open it up so it fits around the first one- then crimp again. It effectively makes the crimp jaw smaller, having the additional ring thickness inside the jaw, which gives a perfect squeeze on the inner ring. If you know a good machinist, you could have a 1" jaw milled out to the right diameter. Yes it seems hokey, but it's certainly better than hose clamps and barb fittings.
  • Karl Reynolds
    Karl Reynolds Member Posts: 80
    Look at Uponor's part number 505851. They are 32mm compression by 1" MPT. I have four of them but Uponor has more than thirty-two.
  • Matt_67
    Thanks everyone - I appreciate the help. I'll be using the compression fittings on this one but that 1-1/4" PEX idea is a good one too.
