Concentric radiator
PMart
Member Posts: 3
I own all the Holohan books and have read them and I swear I’ve seen this set up and I can’t find it anywhere. Isn’t that the way of things lol. I’ve got a customer who wants to replace this rad with baseboard. It’s my hope I can convince them otherwise. What can you tell me about this set up to help my research efforts as to wether or not this is a good idea. I have not been on site yet. This is customer pictures. Tia!0
I won’t know until I get on site tomorrow. They just bought the house and they don’t know what they got yet. If the radiator valve is the correct valve then I’m guessing hydronic0
Mattmia2, those were my concerns and why I thought to reach out to this knowledge base, Incase one of you guys have come across this and had to switch it up.
I don't think the being fed from one end is an issue unless that is some sort of weird steam valve (but I think it is probably hot water). You can always sneak a return behind or under its replacement or use a valve with a lance. The bigger issue is being able to balance it with the rest of the system.1
- 119 Chimneys & Flues
- 76 Pipe Deterioration
