Conversion
Hi everyone. New to forum. Curious if there is a way to remove a stainless steel heat exchanger gas fired and replace with a hydronic coil. I recently installed a navien combination unit to replace hot water heater and use for some radiant installation. I see there are coils to install in the plenum above furnace but I'm curious if there's a way to pull out the burner assemble and stainless and replace with a large hydronic coil to occupy the same housing space. Or is it t simply a matter of replacing the furnace entirely with a hydronic one. Thank you in advance
Derheatmeister
    EBEBRATT-Ed Member Posts: 20,093
    So basically convert the furnace to an air handler? Yes it could be done. More common to add a coil in the ductwork is $$$cheaper and easier. To pull the heat exchanger and put a heating coil in it's place it could be done by someone with good sheet metal experience
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    IMO it is not worth trying to jerry rig something.....Lifebreath makes a good hydrocoil unit...
    BTW..You probably should run the coil on a high temp curve with a minimum setpoint to avoid blowing cold air... And the infloor portion at low temperature depending on your system design criterias
    In other words : I would set it up as a two temp system..
