What is this?
Zman
Zman Member Posts: 7,611
This might be a super simple question. The photo is a non-potable connection on a composting toilet. What is it called and how do I connect to it?
TIA
Albert Einstein
    mattmia2 Member Posts: 14,797
    Looks like that standard flat flanged tubing with a washer and nut connection that any toilet uses but left hand thread on the nut.
    hot_rod Member Posts: 26,064
    Called a bulkhead fitting, they come in all different sizes. It may be an odd thread, usually they have an NPT internal thread.
    looks like the external thread is stepped, maybe for a toilet ballcock nut? Or standard lav faucet nut?
    If i'm not mistaken, it is left hand thread. That might be part of the nonpotable code.
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,975
    Hi @Zman , It's hard to tell, but it looks like it might be threaded on the inside as @hot_rod says. If so, you may have an easy right-hand thread to play with. Tightening that thread would only snug the exterior left hand thread, so no leaks happen.
    Yours, Larry
    i missed the "hey is it threaded inside" part.
  • Zman
    It is not threaded on the inside but it might allow for an internal glue connection. It is the domestic connection for a large composting toilet.
    https://clivusmultrum.com/
    I may need to call them in the morning.
    Albert Einstein
    Yes you can get glue type also. Usually the connection is made inside due to the left hand thread on the nut.
